Maximum rated capacity of davit for pressure vessel
I'm designing a davit for a pressure vessel (lifting of a blind flange) using an excel program which requires the value of "Maximum rated capacity" of the davit. What is it?
The davit is made of c.steel pipe.
Thank you
Thank you
RE: Maximum rated capacity of davit for pressure vessel
Read your own question.
How do you expect anyone to provide any sort of meaningful answer when you have provided exactly zero information?
Further, if you are designing the thing, shouldn't you know the needed capacity?
Do you understand how the Excel program works? Maybe you need the author of the program to explain the terminology.
JHG
If you're designing several "standard davits" for your facility, then you make them certain standard capacities and you may wind up using the 500-lb capacity davit for a 200-lb blind.
That's what I did. Thank you all
How are we to evaluate your opinion of your own work - though I do admire your honesty and your integrity of (1) recognizing a potential problem and (2) asking for a fix.
But, literally, we cannot help when there is no data!
