Batch mode from vb.net
How can I use CV5 batch mode using vb.net? would this be possible?
RE: Batch mode from vb.net
Probably vb.net syntax is a little different, but this is how I did it in Excel VBA, launching from a button on a form:
CODE --> VBA
Private Sub StartCatiaBatch_Click()
Dim CATIA As Object
Set CATIA = CreateObject("Catia.Application")
CATIA.Application.Visible = False
End Sub
I have tried Visible but does not look as batch mode, it is as slow.
More than this, it is funny that I still can see some toolbar flashing :)
use a command line with -batch to get CATIA in batch mode as explained in the online Doc.
google VB Process.Start
Eric N.
I don't quite get it. If I understood right, with batch mode I could start only a .catscript?
Is it not possible to use the code written in vb.net?
the script from batch could call an exe I guess...
Eric N.
