Tolerance for sagging at Beam to Beam Weld joint
Dear Experts,
During fabrication of Tank Roof structure, we are facing some distortion / sagging at Beam to Beam butt welded joints (A992 W shapes).
Can you guide me how much is the tolerance for it and which reference documents to be referred (AISC or other)?
RE: Tolerance for sagging at Beam to Beam Weld joint
Sorry for making you inconvenient.
It's rafter member butt joint and distortion is happened at butt welded joints.
Kindly refer the attachment which may give you better idea.
Appreciate your guidance,
Patel
IF there's any overgrinding visible then the capacity of the member/section is reduced and it needs to be repaired.
