Can we attach the Ejector pin Number populated from Ejectror pin table to the part data
Can we attach the Ejector pin Number populated from Ejector pin (A-1,A-2 ,etc) table to the Ejector pin as a text/curves so that
it can be engraved on the machine,and also is there any setting to remove the arrow and just leave the text part.
Girish.
Girish.
RE: Can we attach the Ejector pin Number populated from Ejectror pin table to the part data
From the picture I see that
you used the drafting hole table
to build these marked arrows.
Is it ?
thanks.
