Transform coordinate system
I have a little confusion on applying transform coordinate system for particular node sets. Can anyone give idea on how to select the required transform coordinate system for a particular node set?
Thank you.
RE: Transform coordinate system
In preprocessing or postprocessing?
In preprocessing
Coordinate systems are used to assign boundary conditions, loads, material orientations (or, in general, vector fields), etc. Typically, you create local coordinate systems using tools in CAE and then refer to those in the BCs/loads/material orientations/..
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
