ASME UHX 13.5.6 STEP 6 Dj INPUT
Dear All,
As the ASME sec.VIII Div.1 UHX 13.5.6 STEP 6,
I knew the Dj value input just like Figure UHX-13.1 skecth (a) that it is.
And I think the Dj value from expansion joint of "thick" type such as appendix 5.
My question is, if I apply the bellow type as appendix 26,
how about the Dj value to be input from bellow dimension?
How do decide the Dj value as U type bellow and toroidal type bellow from appendix 26?
RE: ASME UHX 13.5.6 STEP 6 Dj INPUT
ChiangJaron, Dj is the ID of the convolution (as defined), and can be found from the sketches in Figure 26-1-1. You just have to do the arithmetic.
Mike
