Rigidity of a Non Slip Connection
Hi, so I know that bolted connections can be designed as semi-rigid, however would a designing a pre-loaded non slip bolted connection as fully rigid connection make sense or is there still a some element of flexibility in the connection. Thanks
RE: Rigidity of a Non Slip Connection
BA
