NXOpen - How to Determine if a part is already open
Dear Forum,
I am looking for a snippet of NXOpen code to determine if a part is already open.
I use the following lines of code to initially open the part:
Dim part1 As NXOpen.BasePart
Dim partLoadStatus1 As NXOpen.PartLoadStatus
part1 = theSession.Parts.OpenBaseDisplay(mWorkingFolder & "\" & "example.prt", partLoadStatus1)
partLoadStatus1.Dispose()
If I run this code of a part is already open NX blows up. I need to first check whether the part is open in NX before opening.
RE: NXOpen - How to Determine if a part is already open
The 'session' object has a .Parts collection that holds information on all the currently open parts in session. You could check the file names of the already open parts to see if your part is already in session before attempting to open it.
www.nxjournaling.com
yeahh -
You can also use something like this:
((ufs.Part.IsLoaded(fileName))
CODE -->
If ((ufs.Part.IsLoaded(fileName)) <> 1) Then
                                ufs.Part.OpenQuiet(fileName, tags, ls) 'openQuiet
                                partTag = ufs.Part.AskPartTag(fileName)
                                ufs.Assem.SetWorkPartQuietly(partTag, pre_tags)
                            Else
                                partTag = ufs.Part.AskPartTag(fileName) ' replaced "Displayed part" to "Quiet open part"
                            End If
