Vertical Axis Wind Turbine Vibration Measurment
Hi all, I am currently experimenting with a VAWT (Vertical-Axis Wind Turbine) design and would like to know how i can measure the vibration caused by the spinning of the turbine. (no faster than 400rpm). If i could just recieve some suggestions on the different instruments used or methods i can achieve this it'd be very helpful. Thanks.
Ken
