For 2 TJI joists ends touching free
For 2 TJI joists ends touching freely at a point resting on top of a beam, should any special connections (web stiffener?) be used if only top-down forces are acting on the TJI joists? The TJI joists will have roofing resting on the top flange. Thank you
RE: For 2 TJI joists ends touching free
Dik
That might even be a manuf. requirement.
