Any chemical sensor expert?
If a sensor can detect 0-2000ppm of a substance, let's say oxygen, and the response time is eg 1sec, what is the maximum amount of that substance that is 'processed' in that sensor per second? ie. what maximum amount of that substance does hit the electrodes to generate signal? Is it 2000ppm? Is it possible to calculate the amount of the substance per second?
thanks
