Restraints of crane
Restraints of crane
Hello!
I am new to the forum, but need some help.
I am currently working on a project where i am designing a movable container crane. The design is fairly simple and resembles a straddle carrier or mobile boat lift. I am currently working on the structural analysis and for one of the load cases i am simulating a crash. I have the energy balance and spring constant down but i am having some trouble defining the restraints of the "wheels". The case is that the crane is colliding with one leg. My proposition per now is this:
3 legs free in x,y and locked in z. 1 leg locked in x,y,z and rotation. I have a feeling this is not the best solution but as i said i am having some trouble coming up with something that works better.
RE: Restraints of crane
I'd suggest supporting each wheel on 3 rods of some stiffness and constraining the far ends of the rods; to give the wheels finite stiffness. Then ask yourself "could some of these wheels move?".
i suggest to leave that 1 leg that hits an object free to rotate in whatever direction it wants, even torsion so to say
then simulate and find out xyz deflections and 3 rotations of the leg
So look at this problem as if the crane is in rest and a object hits that one leg
Constraining all 4 points in z is an acceptable compromise (saying the flat base remains flat) and constrains 3 freedoms (Fz, Rx, Ry). So you need 2 x and 1 y (or 1 x and 2 y) to take out the other 3 freedoms (Fx, Fy, and Mz).
Better than hard (infinitely stiff) nodal constraints is to apply a finite stiffness at each support. My suggestion is three orthogonal rods at each support point, and hard constrain the far ends of these rods.
Then only add a collision force at one leg.
Then simulate and conclude what deflections and stresses that one leg will show.
Your method of adding orthogonal rods will also work by the way.
