Pressure tested and fire safe terms
hey
I read this information on internet that when a valve is said fire safe it means the design is fire safe and it is not fire tested while if it is said by the manufacturer that valve is fire tested then only it has been 100% fire tested.
So my doubt is while the maunfacturer writes in catalog that the valve is presure tested, does that mean manufacturer has to pressure test every valve before dispatching it to the customer?
Curiosity to learn new things everyday.
RE: Pressure tested and fire safe terms
Not my place to judge, but I think you should communicate more to the manufacturer prior asking general forum (this forum members also consist of manufacturer, general practitioner, end user, supplier and student). Don’t get me wrong, your question is good (and I believe some people will ask the same too), but the circumstances and background for other people/companies may be different.
Anyway:
  • Fire test is referred to ISO 1049. Test report should consist “name and affiliation of individuals witnessing the fire test”. Usually someone from approved NoBo (notified body)
    What is this means in general? Valve A tested in year 2000 and pass the fire test. Thus, all exact similar valve design (sizes may vary slightly) with exact same components for xx years ahead is also fire test approved. Thus, every valve production batch afterwards do not require to be fire-tested.
    If new development occurs (for instance valve A w/ old type hard facing becomes A+ - newer version of hard facing) or customer want a similar valve but different packing (valve A altered and becomes B), then manufacturer should re-new the fire test
    IF you are potential and strategic customer, then manufacturer may share this documents with you. But if you're not, don’t be surprised if they’re willing not share this information (read: their document + Photoshop = new fake document)
    If there is no alteration in the design from testing year until now, is the document still valid? This is for you to judge.
  • Pressure test --> this should be clarified with the supplier
    Some company produce 1-10 valve per day, some (giant) companies produce hundreds of industrial valves/day. And 15 minutes (body test + seat A + Seat B + handling) per valve cannot meet with such production speed. Due to limited test bench and it is not advisable for rush working under pressure.
    So some companies indeed test all the pressure test 100%,
    But there is also a consensus that if the valve is not critical and industrial (again this can be interpreted widely), and as long as it is part of production batch (performed by same qualified assemblers), then inspector will perform 100% visible visual inspection and tester will perform 10% of pressure test. If result is satisfactory, then the other 90% might be subject for acceptance.
    manufacturing - assembling - pressure test - storage (for xx months or years) - send to customer. Do they need to be re-test the valve before sending it to customer? Traditionally no, unless you and manufacturer agree on such deal to do so.
  • Imagine a different building and department in-charge between storage area and pressure test. Re-test one or five valve that you have place the order with is considered not economical for some supplier
Kind regards,
MR
https://nosuchvalve.com
All valves will last for years, except the ones that were poorly manufactured; are still wrongly operated and or were wrongly selected
http://www.eng-tips.com/faqs.cfm?&rat1=2&f...
As usual, Danlap has good advice. To add to Danlap's comments:
1. Fire testing may also be carried out to API 6FA or API 607 (or possibly other standards). Fire testing is carried out on one representative sample valve and does not need to be repeated unless there is a significant change to the valve design. This test exposes the valve to high temperature and the actual valve that was exposed to the flames would normally not be sold after the test, as it may be weakened/damaged from the high temperature exposure during the test. I agree with Danlap that the manufacturer might not want to share all the testing information/documentation with you unless you are a particularly important/strategic customer.
2. Hydro-testing is not a destructive test (unless the part is significantly defective) and is often part of factory acceptance testing on all completed valves. For some applications, it is normal that 100% of valves are hydro-tested at the factory, and for some other applications, sampling may be used. Again, I agree with Danlap that you should confirm with the manufacturer which one is the case.
@danlap thanks and I do ask the manufacturers first but yeah I got your point.
@jmec87 thanks for making things more clear.
Thanks jmec87, for an awesome remarks and that standards (I forgot about API 6FA and 607)
You're welcome NDS21
MR
