NX NASTRAN 10 IS SOLVING A PROBLEM WITHOUT ANY LOAD ..HOW IT IS POSSIBLE
Hello
i am using nx nastran 10.when i solve a linear static solution, with out any load , it is getting solved and giving zero displacement results which is correct with a zero load.
But when i use nx 9 ,when there is no load in the linear static solution .when u click on solve,it will give a warning saying there is no load in the soltion .and it will not solve the solution.
Can any one tell me how come nxnastran 10 is solving a solution without anyload.
RE: NX NASTRAN 10 IS SOLVING A PROBLEM WITHOUT ANY LOAD ..HOW IT IS POSSIBLE
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
