Cyclic Displacements in ANSYS Workbench
RE: Cyclic Displacements in ANSYS Workbench
jmatrix
Your problem is not clear. What are your difficulties exactly?
Simple stress life approach- Do two step linear static structural analyses with 0.3 mm displacement load and 0.27 mm displacement load. You will get the range of the stress(max minus min) from which you can do fatigue life calculations.
This looks like a two-body structural analysis with a contact surface. Here are steps that you could try: (assume geometries have been imported/created, and meshing is completed)
1. assign material to each body
2. add a contact pair object and define the target and contact surface
3. add a fixed boundary to the top body
4. add a displacement boundary to the lower body.
For the fatigue solution, you could add fatigue result object and evaluate.
https://welsim.com
