NXOpen - Dual Dimensions
Dear Forum,
How do I find out if a dimension is dual dimensioned with NXOpen?
RE: NXOpen - Dual Dimensions
That's great. But I am cycling through the dimensions in the workpart. How do I get the
annotations properties of the "dimension" object. Code Snippet Below:
For Each myDim As Dimension In workpart.dimension
Dim editSettingsBuilder1 As NXOpen.Annotations.EditSettingsBuilder
editSettingsBuilder1 = DrumMaterialDrawingPart.SettingsManager.CreateAnnotationEditSettingsBuilder({myDim})
If Me.rbMetricOnly.Checked Then
editSettingsBuilder1.AnnotationStyle.UnitsStyle.DualDimensionFormat = NXOpen.Annotations.DualDimensionPlacement.None
Else
editSettingsBuilder1.AnnotationStyle.UnitsStyle.DualDimensionFormat = NXOpen.Annotations.DualDimensionPlacement.Below
End If
editSettingsBuilder1.Commit()
editSettingsBuilder1.Destroy()
Next
Quote (EngProgrammer)
Check the value of the .DualDimensionFormat; if it is set to "None", it is not dual dimensioned. If it is set to one of the other styles, it is dual dimensioned.
www.nxjournaling.com
Hi Cowski,
I don't see "DualDimensionFormat" as a property of the dimension object.
I am cycling through all the dimension in the workpart using the loop below. I am not seeing "DualDimensionFormat" as a property or method of mydim object of a dimension class.
For myDim as dimension in workpart.dimensions
next
You can access it through the settings builder as shown in your previous post.
Looks like you can also get it through the dimension preferences.
CODE
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module2
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "report dims")
        lw.Open()
        For Each tempDim As Annotations.Dimension In theSession.Parts.Work.Dimensions
            lw.WriteLine("tag: " & tempDim.Tag)
            If tempDim.GetDimensionPreferences.GetUnitsFormatPreferences.DualDimensionPlacement = Annotations.DualDimensionPlacement.None Then
                lw.WriteLine("-- not a dual dimension")
            Else
                lw.WriteLine("++ dual dimension")
            End If
            lw.WriteLine("")
        Next
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Aha. A double get. Good find. I was looking at the first level of the dimension class property under the "getUnitsFormarPreferences" but I was only looking at the properties I didn't check out the methods.
I like using this one instead of getting it from the builder. It makes sense because both of these classes are in the Annotations namespace.
