Solid Modeling conception..................
Please, have a look at the picture below:
Let's say you are asked to create a solid model from the given features ( 2 sketches and a guide).
What workbench and feature would you use to create it:
A) Part design:
1. Multi-Sections Solid
2. Rib
B) Generative Shape Design:
1. Sweep:
- Explicit (3 different option)
- Line (7 different option)
- Circle (7 different option)
- Conic (4 different option)
2. Multi-Sections Surface Definition
C) Other tools
Thank you,
CAD 2015
A) Part design:
2. Rib
1. Sweep:
C) Other tools
Thank you,
CAD 2015
RE: Solid Modeling conception..................
If the two profiles are the same, then I would use the Rib command. If the profiles are different, then I would use the Multi-Section Solid.
(I would also add a Spine curve)
CAD 2015
but like Jackk already said, if at the end you need a solid then go with solid function, if you need surface or volume then go GSD...
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
CAD 2015
Tiago Figueiredo
Tooling Engineer
Youtube channel:
https://www.youtube.com/channel/UC1qdlBeJJEgMgpPLV...
CAD 2015
With all that said, I wouldn't use rib.
So, what would you use instead?
CAD 2015
