Creating new Field in ODB File
I am trying to create new field in ODB file. But for testing purpose, I just decided to read "old" stress field and re-create it as new one. So, I read S23 from ODB, create array (Element label, time, stress 23), and create new Field with the same values.
When I print out the values (Elt number, Stress), I have the same values.
But the contours look different.
Can anyone help?
Leon
#Opening ODB
odb = openOdb(path='out34.odb')
step1 = odb.steps['Step-1']
frames = odb.steps['Step-1'].frames
numFrames = len(frames)
lastFrame = odb.steps['Step-1'].frames[-1]
myInstance = odb.rootAssembly.instances['BOX-1']
numNodes = len(myInstance.nodes)
numElements = len(myInstance.elements)
# Nodes and elements
N = myInstance.nodes
EL = myInstance.elements
#-Creating Array of 3 columns: Ti
ncolum=3
strehi=np.empty((ncolum, numElements*numFrames), dtype=object)
Nums=0.
for x in odb.steps['Step-1'].frames:Element No, Step Time, Stress S23
currentsteptime = x.frameValue
print ' Time/Incr is ', currentsteptime, x.incrementNumber
stress=x.fieldOutputs['S'].getSubset(position=CENTROID)
maxstr=0.
nustr=0.
for S in stress.values:
strehi [1, Nums*numElements+nustr]=currentsteptime
strehi [0, Nums*numElements+nustr]=S.elementLabel
s11=S.data[0]
s13=S.data[5]
strehi [2, Nums*numElements+nustr]=s23
nustr=nustr+1
Nums=Nums+1
# Adding new Field to ODB
field1 = lastFrame.FieldOutput(name='Mgu04', description='none', type=SCALAR)
elmdata=()
elmNo=[]
elmdata=[(strehi [2, index],) for index in range(numElements*(numFrames-1), numElements*numFrames)]
for index in range(numElements):
ind2=index+numElements*(numFrames-1)
elmNo.append(index+1)
val2=strehi [2, ind2]
field1.addData(position=CENTROID, instance=myInstance, labels=elmNo, data=elmdata)
Can anyone help?
Leon
#Opening ODB
ncolum=3
Nums=0.
maxstr=0.
nustr=0.
s11=S.data[0]
s13=S.data[5]
nustr=nustr+1
Nums=Nums+1
elmdata=()
elmNo=[]
RE: Creating new Field in ODB File
