Hydronic system fill PRV setting?
I know from the following that a PRV should be set to maintain 4PSI at the top of the system for "positive venting".
https://www.deppmann.com/blog/monday-morning-minut...
But what if the PRV is actually at the top of the system? (Same elevation as my chilled water piping). Do i just set it at 4PSI? Or should I use a minimum of some other pressure?
RE: Hydronic system fill PRV setting?
