nx 10 drafting view update
I am using NX 10.0. in which i have issue on drafting view update after model update.
The thing is that already I have done modeling and drafting in assembly file. in which I changed/replaced some components and went to drafting and the changes not displaying in views after giving update. But when I took new base view it came with changes.
since already i did some drafting in existing view i would like to utilize that view but i am not able to update the view with current change.
please guide me how to reflect changes in existing drafted view.
RE: nx 10 drafting view update
After the model update did you also update the drawing views? Right click the drawing sheet in the part navigator and choose "update".
Also, check the view settings and make sure the view is not marked as "snapshot"; this is an option that you can toggle on/off. Views in snapshot mode do not update with model changes.
www.nxjournaling.com
