Helix - SAP2000 - Show without twist the elements
Hi!
I need to create a mesh with helix elements, like a spring. The elements are 6 x 3 mm (cross section), can be frame elements. I know the Extrude Points to Lines (radial), build the mesh, but when i choose extrude view, some elements are showed twisted. I would like that the external face of the element goes external for the entire spring. Please, see the attached file.
AAP.
AAP.
