Select circles in drawing view
I want to select all circles inside a view in drawing.
Any idea to do it. I tried the find command, but all constructions inside a view are called "Generated item", So it's not easy to create a filter.
Tiago Figueiredo
Tooling Engineer
Youtube channel:
https://www.youtube.com/channel/UC1qdlBeJJEgMgpPLV...
RE: Select circles in drawing view
By the way, I found this.
http://catiadoc.free.fr/online/mtdug_C2/mtdugbt070...
But I don't have the required license...
I need an easy way to select the holes in drawing....
Tiago Figueiredo
Tooling Engineer
Youtube channel:
In View-properties you can add Center Line as Dress-upp--will that help?
regards,
LWolf
Tiago Figueiredo
Tooling Engineer
Youtube channel:
I have all of the needed holes with technological results. Is possible to retrieve all the information from the 3d and insert the information in drawing, like coordinates, and type and dimension of hole?
Tiago Figueiredo
Tooling Engineer
Youtube channel:
