function of holes in choke valves body
Dear All,
There is 4 holes in choke valve body area which is in closed condition.Can anyone tell what is the function of these holes and why it is required.
RATHEESH N
RATHEESH N
RE: function of holes in choke valves body
Some sort of plugged off port, but whether that was there as a manufacturing aid or whtehr it is for options which were not valid for that valve it's impossible to tell.
Could be mounting bolts for something?
Find a cross section drawing of the valve or do some research on that manufacturer or valve type which you haven't shared with us
