Importing Image with transparency into drafting
Hello All,
Struggling with this feature in NX. I am trying to insert an image into my drafting sheet but have some issues with that.
Using "insert - image" I select an png image with transparent background. The problem is that the transparent background shows as white on my Drawingsheet. So I end up with a big white rectangle.
When I do the same in Modeling the transparency is working correct and I only see what is meant to be seen.
This happens both in NX9 and NX11.
Anyone else have the same experience? Solutions?
(I checked the image by importing it into MS Word and also there the transparency is working as expected)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
RE: Importing Image with transparency into drafting
Simple answer is it's not possible to have the transparency work in drafting.
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
