revised code edition of ASME sec. VIII DIV. 1
As per ASME SEC. I mandatory appendix VI-1, it is mandatory to use revised code edition after 6 months of issuance date.
I don't find such requirement in Sec. VIII DIV1 .
Where such requirement is mentioned in Sec. VIII DIV1 ?
RE: revised code edition of ASME sec. VIII DIV. 1
Mandatory appendix 43, para 43-1(a).
thanks XL83NL (Mechanical)
If the Contract was started before the new Revision came into force then you should be able to use the Revision that was in force at the signing of the Contract.
DSB123 (Mechanical) thanks.
