lame question about mass properties
hello coleagues
in WB 17.1 when i import a geometry and specify density in engineering data i got the mass of the geometry.
in wb 18 i do same thing but it does not calculate mass (mass = 0). even if i use default structural steel as a material, it still does not calculate mass...
hence modal analisys is impossible.
structural analysis works fine , which means E and P. ratio are fine, just density makes some trouble...
any ideas ?
any ideas ?
RE: lame question about mass properties
maybe it needs to be reinstalled...
In theses cases mesh generation was however successful and mass was correct in solver's
mass summary.
can it be the xml file of materials somehow, idk?
