simple way to calculate reaction force of a rupture disc
Is there any simple formula to calculate reaction forces created when a rupture disc burst? It is 6 inch steel pipe with mining backfill paste with density of 1800 kg/m3 and rupture disc rate for 80 bar. Can I assume max force created during bursting will be rated pressure of 80 bar multiplied by cross section area on 6 inch pipe?
I was unable to get some data from vendor. Any input will he helpful
RE: simple way to calculate reaction force of a rupture disc
Or into any kind of bend or long pipe, any closed pipe or tank that will slow the slug of liquid coming down the pipe?
There is a tee on main line and rupture disc is branched off the middle nozzle side of tee and will release to atmosphere. flow direction of material leaving rupture disc is vertical to main line flow direction on top side . I might add elbow after rupture disc to direct it to somewhere else based on available space but for sake of argument assume it releases directly to atmosphere. I guess with this configuration the reaction force will be perpendicular to main line and hence creating bending forces on tee nozzles. I have selected grooved coupling for tee disregard the coupling type there should be a simple formula for reaction force. Also when rupture disc burst the burst area is not necessary equal to pipe cross section area and most probably smaller but for simplicity assume it will be equal to pipe cross section area.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
