ASME Code Edition for New Construction - Latest vs Latest Adopted
I have a general code question that has always confused me. When establishing the effective ASME Code for a new construction project, we have typically used the latest "mandatory" edition at the time we sign the contract. For example, a Section I boiler contract is signed Jan 2, 2018, so we use the 2017 Edition for Design and Construction (2017 Ed becomes mandatory 6 months after date of issue per Mandatory Appendix VI).
On the other hand, state jurisdictions (ref. NB-370) often show the latest adopted Edition for each state. Alabama for example says "ASME Code (2015 Edition)" for new construction.
My question: Does this mean if the contract signed in paragraph 1 above will be installed in Alabama, that I have to use Section I 2015 Edition? I wouldn't think so, but if true then wouldn't the statement in Section I, Mand Appendix VI be contradictory?
Thanks for any help or advice resolving my confusion.
RE: ASME Code Edition for New Construction - Latest vs Latest Adopted
Another example is ASME Code Cases. Some Jurisdictions allow them others do not.
Mike
