Problem with line type in Sketcher
I am having an issue with creating regular lines in sketcher. They come out as thick center lines. How do I change this?
RE: Problem with line type in Sketcher
In customer defaults in sketch section.
Does this only affect lines in a sketch? If you create a line outside a sketch, does it have the same appearance?
www.nxjournaling.com
