SA-578 SUPPLEMENTARY REQUIREMENTS S1
The ASME UT procedure SA-578 with supplementary requirements S1 as :
S1.1 Scanning shall be continuous over 100 % of the plate
surface along parallel paths, transverse or parallel to the major
plate axis, with not less than 10 % overlap between each path.
Can anyone tell me what's means " with not less than 10% overlap between each path"?
If possible, please give me a sketch for easy understanding.
RE: SA-578 SUPPLEMENTARY REQUIREMENTS S1
