Not able to solve Example 3.1.1 Symmetric results transfer for a static tire analysis in abaqus
Hi ,
I am newbie to abaqus and is trying to learn it solving some examples but is facing problem running Tiretransfer_symmetric in abaqus.
This is how i procceded :
Open Abaqus command -> using command abaqus job=tiretransfer_axi_half (this runs fine) -> using command abaqus job=tiretransfer_symmetric
Below is the Error i got :
Analysis initiated from SIMULIA established products
Abaqus JOB tiretransfer_symmetric
Abaqus Student Edition 2016-SE
Begin Analysis Input File Processor
3/15/2018 7:45:00 PM
Run pre.exe
Abaqus Error: Analysis Input File Processor exited with an error.
Abaqus/Analysis exited with errors
I am using Student Edition , Is this the cause of Error ? but tiretransfer_axi_half runs fine.
please help!
Run pre.exe
please help!
RE: Not able to solve Example 3.1.1 Symmetric results transfer for a static tire analysis in abaqus
When you submit an analysis several files are generated. You should check the .dat file and .msg file (if it exists) to find the exact error you have encountered.
