General formula for torsion section modulus
Is there one single formula which can give the torsional section modulus for all shapes (either solid or hollow)? I want to write a script for the same.
Dividing the polar moment of inertia with the extreme fiber doesn't give the right results for all shapes.
Su
RE: General formula for torsion section modulus
at a minimum I think you'll need different expressions for open or closed sections.
For open sections, you can use J≈ Σ(bt3/3) [where b/t ≥10]
where b= length of each cross-sectional element & t= thickness of each cross-sectional element
For closed sections, there are various formulas.
