How to create iterations that fixes errors VBA
I come with a new set of questions. I want to create a extrapol with a given value(ex: 50). If the extrapol creates an error the it should decrese the value with 1 until the operation has no errors.
In this moment i have a structure like this:
___________
Dim j As Integer
For j = 1 To SearchSelection.Count
Set hybridShapeSurfaceExplicit2 = SearchSelection.Item2(j).Value
Set reference2 = part1.CreateReferenceFromObject(hybridShapeSurfaceExplicit2)
Set hybridShapeBoundary2 = hybridShapeFactory1.AddNewBoundaryOfSurface(reference2)
Set hybridBody2 = hybridBodies2.Item("Complete Boundary UNTRIM")
hybridBody2.AppendHybridShape hybridShapeBoundary2
part1.InWorkObject = hybridShapeBoundary2
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridShapes2 As HybridShapes
Set hybridShapes2 = hybridBody2.HybridShapes
Dim parameters1 As Parameters
Set parameters1 = part1.Parameters
Dim a As Integer
a = 50
Set reference7 = part1.CreateReferenceFromObject(hybridShapeBoundary2)
Dim hybridShapeExtrapol1 As HybridShapeExtrapol
Set hybridShapeExtrapol1 = hybridShapeFactory1.AddNewExtrapolLength(reference7, reference2, a)
hybridShapeExtrapol1.ContinuityType = 1
hybridShapeExtrapol1.BorderType = 1
hybridShapeExtrapol1.LimitType = 0
hybridShapeExtrapol1.SetAssemble True
hybridShapeExtrapol1.PropagationMode = 0
hybridShapeExtrapol1.ExtendEdgesMode = False
hybridShapeExtrapol1.ConstantLengthMode = False
Set hybridBody3 = hybridBodies1.Item("Untrim Extrapolated")
hybridBody3.AppendHybridShape hybridShapeExtrapol1
part1.InWorkObject = hybridShapeExtrapol1
part1.Update
On Error Resume Next
If Err.Number <> 0 Then
a = a - 1
Else
End If
Next
But i do not see a change in value even if the extrapol has an error.
Please help!
___________
Dim j As Integer
Dim a As Integer
a = 50
part1.Update
a = a - 1
Else
End If
Next
Please help!
RE: How to create iterations that fixes errors VBA
- create the extrapol;
- append it;
- now create the loop: inside the loop do the update and if the update fails EDIT the extrapol (do not decrease the "a" as it makes no sense). I prefer a do-while loop for this kind of scenarios.
- exit the loop when err.number <>0
later edit: careful with On error resume next. You have to use the On error goto 0 clause to reset it.
Calin
