Splitting a document or part name
Hi guys,
I have found this line of code that will remove the instance number from the part number.
strNewNumber = Split(CATIA.ActiveDocument.Name,".")(0)
Can anyone tell me if you can use this to edit the part number itself.
eg remove the first 2 numbers and the last 2 numbers? (123456789.1 to 34567.1)
I can't find anything that explains how to do this using this command
any help would be really appreciated.
thanks
Alan
RE: Splitting a document or part name
this forum is more about CATIA question, your is a VBA question.
you can turn your number into a string with CStr(thenumber) then doing a mid(thestring,x,y) to keep what you need, then convert back to a number with Val(theString)
in your case :
CODE --> VB/VBA
newnumber = Val(Mid(CStr(yourNumber), 3, Len(CStr(thenumber)-4)))
Eric N.
Hi itsmyjob,
The question was about a catia script.
I have tried to find examples but with virtually no luck.
I have used the line I mentioned before in a bit of code for removing the instance number (someone here gave me, may have been you)
Thanks for the pointer its appreciated.
regards
Alan
my code is more VBA, not sure how that will work in CATScript
Eric N.
I'm not sure if this is me or the code doesn't work in cat script.
Keep getting a string mismatch error.
More than likely me but could someone tell me?
thanks
Alan
Dim nSel
nSel = uSel.item(1).value.name
Dim nSel2
nSel2 = nSel
CStr(nSel2)
Dim nSel3
nSel3 = Val(Mid(CStr(nSel), 3, Len(CStr(nSel2)-4)))
Assuming your string always has one and only one "." in it, try this piece:
CODE -->
myString = CATIA.ActiveDocument.Name
myNewString = Mid(myString , 3, InStr(myString , ".") - 5)
Thanks cilici
That seems to work removing the numbers from the front of the part number but removes the instance number when trying to remove the last 4 digits.
Is there away to keep the instance number ?
regards
Alan
hi guys,
did it by doing to cuts one for the part number and one for the instance number.
if thers a better way it would be nice to know.
cheers
Alan
