Determination of ID and OD at Cryogenic Temperatures
I have a 316 SS tube with an I.D. of 0.43″ and O.D. of 0.5 ″. Could someone please advise me on how I would calculate the I.D. and O.D. of the tube at cryogenic temperatures? The linear thermal expansion percent (L – L293/L293) at a temperature range (0 K – 300 K) is the only material property that I have access to. Thank you!
RE: Determination of ID and OD at Cryogenic Temperatures
NIST publishes good low temp CTE data. It isn't linear.
I perhaps should have asked, if the percent change in the length of the tube for a given temperature difference is the same as the percent change in its diameters individually?
If the cross-section were to contract with the expansion in length, would the Poisson's ratio figure in the expression?
The tube will get larger in diameter, thicker wall, and longer as it gets hotter.
Based on your statement, will the below expressions suffice? Thank you.
OD (Temp) = OD (293) + alpha (Temp)
ID (Temp) = ID (293) - alpha (Temp)
so CTE x delta T x original size = change in size
I believe that the NIST formula is a 5th order fit.
http://cryogenics.nist.gov/Papers/Cryo_Materials.p...
http://www.dtic.mil/dtic/tr/fulltext/u2/438718.pdf
But this one has curves (not equations).
