Femap template
Femap template
Femap template
Hi al!
I am using Femap and finally i have a file with al my preferences, materials and properties.
Is there a way to set this file as a template??
RE: Femap template
you could make a .modfem file with these in it, then start each model with this "template".
RE: Femap template
Hi Rb1957.
I have the template already. But I want Femap to automatic start with it when I open Femap.
I know it is possible, because i have done it before...
RE: Femap template
If you have set these set in your Preferences under the Library/Startup tab they should be saved when opening a new occurrence of Femap.
