Prestressed slab with tendons at the centroid - flexural capacity
I'm designing a slab with prestressing strands running through the centre with no additional reinforcing. Common sense dictates the max moment capacity occurs when stress at the extreme tension fiber is zero, and the strain diagram is a triangle (P/A=M/S). However, per the code, you would end up with a rectangular stress distribution, leaving negligible moment capacity. Can anyone point in the right direction, as clearly the slab has some capacity?
RE: Prestressed slab with tendons at the centroid - flexural capacity
Dik
No, you are confusing elastic stresses with ultimate flexural moment capacity. Such a calc would be called the 'decompression moment' - nothing to do with ultimate moment capacity.
Go back to the typical rectangular stress block, your strain diagram assuming εc=0.002, check your strain in the strand (account for all the strains), assume a neutral axis location, sum the internal forces to be equal (so iterate once or twice), then sum forces (about say top fiber) to calc moment capacity.
Any pesky secondary moments (hyperstatic) to include?
I don't think so. Under ultimate flexural conditions, your compression block is still rectangular and up top as usual. This is similar to Ingenuity's comment I believe.
Like with a concrete column, I think that the natural place to take moments is about the centroid of the compression block with the compression block including the pre-compression.
With your prestress at the centroid of the cross section, and presumably no mild reinforcement, the thing to keep a close eye on is flexural crack widths at the service load level.
Sorry, should have been 0.003 (or what ever the Canucks are doing these days!).
In my defense, my reply was too early in the morning...and before the mandatory coffee
