Invalid "Assignment" > Geometry issue?
I keep getting the Invalid "Assignment" error with the association Project>Model>Geometry>Geom>Geom\Surface.
The surface itself is rather complex & originally from an STL. I have gone through all the fixing routines in Space Claim & the geometry as far as I can assess is valid with no overlaps or bad aspect ratios etc.
How do I find out exactly which assignment ANSYS is complaining about?
RE: Invalid "Assignment" > Geometry issue?
Solved: material properties hadnt been assigned
