Display data asked for shadow of unloaded entity
thread561-395552: Display data asked for shadow of unloaded entity. Same problem as closed thread that was never replied to. It seems to be a problem with PMI. Cannot get back from the model to the parent drawing. the error "Display data asked for shadow of unloaded entity" STOPS me from making the drawing the work part
RE: Display data asked for shadow of unloaded entity
I have never seen this error.
It sounds as if something in the file requires more data to be loaded. ( not sufficient with what's loaded in the session.)
Can you make the assy fully loaded ?
Maybe you should speak to Gtac about this.
Tomas
It shows no solution or workaround however.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
