CANADA REGULATION PRESSURE VESSELS
Hi to All,
We usually work in europe and Asia, and now we have some projects in CANADA. They are requiring to follow B51 regulation. This is for pressure vessels above ground with liquid inside in GRP. Is anyone familiar with it? what secction shall we go? any suggestions?
many thanks to all
Dr Gorostidi
many thanks to all
Dr Gorostidi
RE: CANADA REGULATION PRESSURE VESSELS
The service is sort of filtering water under pressure. It is installed in a fish farm. We have all the papers and certifications for europe, but as you said, we have been required the CRN number, and for this task they have told us to check B51 regulation which is not know by our team
Dr Gorostidi
Mike
In this project the vessel is small (Ø520mm H=2000mm) and pressure in this time is 5 bars (73 psi)
In the rest of the proejcts the pressure is bellow 15 psi
Water temperature: max 25-30º C (86 ºF)
regards
Dr Gorostidi
Please look at the following links below. These links are from the website of TSSA,regulatorsin Ontario. Is this project applies to the other provinces of Canada, you've to search for the rules from the appropriate regulators' website.
https://www.tssa.org/en/boilers-pressure-vessels/r...
Thanks.
Pradip Goswami,P.Eng.IWE
Welding & Metallurgical Specialist
Ontario,Canada.
ca.linkedin.com/pub/pradip-goswami/5/985/299
Our team will check your links. We have made the calculation with ASME, just need the CRN , thanks a lot.
Dr Gorostidi
The project covers
New Brunswick, Prince Edward Island, Nova Scotia and Newfoundland
On the other hand, most are bellow 15 psi I i guess that no CRN number is required, only for those where we have more than 15 psi
am i right?
We are used to European legisltation, which is quite different
Dr Gorostidi
Also every province as stated above have their local BPV jurisdictions, with website. You may find other required details as mandated in each province. It does not harm to call or email them with your queries as as to get the required guidance.
Hope it would help.
Thanks.
Ontario,Canada.
website is: acicrn.com
