tc revision a,b,...,aa,bb,Hiha
Hi
Do teamcenter support the standard
full revision letters.
In my company I deeds a testing and
The last revision is Y.
When I trying AA refused.
By invalid revision error.
Thanks in advanced.
RE: tc revision a,b,...,aa,bb,Hiha
I don't need that.
only curiosity.
and why not if someone need it.
Besides the fact that this is a question which should be asked in the Teamcenter Forum...
The revisioning scheme is configured with the BMIDE tool provided with the teamcenter installation. You can decide yourself how it should look like...
Of course there are some recommendations on how to do it. If i'm correct the o.o.t.b is going like A,B,....Z,AA,AB,AC....AZ,BA.....ZZ
In our TC environment we are starting with a - revision...
So most probably your IT department didn't allow for this revision sequence or it is not allowed to already use it before the single letter revisions are all used.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Ronald thank you.
that as I suspected.
is as a user I can read only see
These bmide setting.
And how. ?
Most probably not as it will be on the server where Teamcenter is running. I expect as a normal user you won't have access.
NX9 / TC10.1.2
Ronald thank you very much.
