CMU properies
CMU properies
CMU properies
I am making a RAM model that I need to model in a CMU wall for. I read online it is more accurate to use the "other" option instead of a concrete wall. When going into the other option it asks for the properties of CMU. One of the properties is the modulus of elasticity.
The equation for E for CMU = 900 (f'm).
I can't seem to find a good answer for what a typical value of f'm would be.
Does anyone have any suggestions?
Thank you
RE: CMU properies
CMU strength is usually between 1500 psi to 2000 psi. Considerably higher strengths can be obtained at a premium, but, for 'run of the mill' type construction the compressive strength will be slightly above 1500 psi.
Dik
RE: CMU properies
Dik,
I understand, what is f'm typically with the combination of the grout and the block?
RE: CMU properies
No, not grout - f'm is the compressive strength of the combination of the mortar and block in an assembled condition.
RE: CMU properies
JAE: thanks...
