AS/NZS 1170.2 Cfig for Cylindrical Tank
Can someone please give me some guidance in determining Cfig for a pressure vessel? Do you compute Cp1(θb) for various angles and sum the results to obtain Cfig? I assume this value is then added to Cfig drag force .63 to obtain the overall Cfig used in the design wind force equation.
Thank you,
Wes
Thank you,
Wes
RE: AS/NZS 1170.2 Cfig for Cylindrical Tank
Seems low compared to building structures though. Section E3 might serve as a cross-check.
