NX12 and Windows 7
NX12 and Windows 7
Siemens has noted that NX12 is supported on Win10 and higher. We are about to upgrade from NX9 to NX12 but are still on Windows 7. Has anyone used NX12 with Windows 7, any known issues?
We will hopefully upgrade to Win10 at the end of the year and were going to go to NX11 but there is a good fix we want in NX12 so I'm hoping going to NX12 now we will be able to live with any small issues until the win10 upgrade later in the year.
NX 9.0.3.4 mp12, TC 10.1
RE: NX12 and Windows 7
If you are on an "unsupported" platform and you have an issue you should try to reproduce it on a supported one before reporting it.
Rob
We're also upgrading from Win7 to Win10, and NX9 runs okay on that OS too,
NX 9.0.3.4
NX 12.0.1.7 (Testing)
Windows 10
One of my customer found an issue when plotting with NX12 on Windows 7. It worked well with NX11.
The result is wrong on the plotter. Have a look at the scanned result
Does anybody encountered the same problem ?
Didier Psaltopoulos
http://www.psi-cad.fr
cheers, James
