best way to reduce 200 bar to 100 bar?
I am working on a project that uses the hydraulic pump of a tractor. The tractor has a openloop-system that has a pressure of 200 bar, with a flow of 52.5 L/min. I would like to power 2 hydraulic motors with a high RPM. I have 2 motors that have a working pressure of 100 bar each, that are otherwise perfect for the job. What is the best way to connect these to the system?
Thanks in advance
Thanks in advance
RE: best way to reduce 200 bar to 100 bar?
If the motors are only working up to 100 BAR, then that is all they need and system won't deliver more than needed.
If you want to limit the motor pressure to protect them against occasional over pressure, then use cross line relief valves.
You would only really need to reduce the pressure if your motor circuit is likely to stall out frequently or if the down stream circuit is a closed system. In this case you would use a pressure reducing valve. However, controlling pressure at that flow rate will require a big valve.
You need to question whether you really need to reduce the pressure or just limit it.
A bit more information: this is the motor i was talking about: https://www.kramp.com/shop-de/en/940241/495059/0/O.... it says the continuous pressure is 100 bar, with max pressure of 140bar (10% of the time) and 200 bar peak.
The pump compensates pressure using load sensing.
If i understand this correctly: If i were to connect this motor to the pump, the pump will sense it only needs 100 bar and not use anymore? even though the system pressure is 200 bar?
Ted
It is the natural fluid dynamics that give only what pressure is needed and no more. That is one of positive points of hydraulic systems. That and the power to weight ratio.
The 200 BAR is the maximum of the pump, not the normal working pressure.
The load sensing is power control that matches the pump flow to the requirement of the motors.
An even better solution would be to install a load sense relief valve and set that to 120 BAR. That way the pump will be controlled by the pressure at the motor and you'll get a better power match between the pump and the motors.
A load sense relief set at 120 BAR would give 120 + margin at the pump (approx 137 to 140 BAR). Once the load sense relief is opened, the pump will reduce its flow.
How you set this up is dependent on the duty profile of the motors and what you want them to do when they get up to max pressure.
In any case, exceeding the fill limit of a motor will cause the pressure to build in the lines up to the inlet port. The motor itself won't see that pressure.
If the outlet is restricted and the motor pressure rises, that would hurt the motor. In this case, the relief valve would catch the pressure anyway.
For a fixed displacement pump, a cross line relief would be best.
As this system has a load sensing pump, it makes more sense to use a load sense relief valve and to set that just above the maximum working pressure of the motors.
Thinking about this, there is a leak connection as well that i can't connect anywhere because it needs low pressure. hmm
Or
Does the handle adjust a valve that varies the margin and thus changes the pump displacement (flow rate)?
There will be a hoses between the pump and that valve. The pressure supply and the load sense line. The return line from the control valve will go back to the tank. You will want to connect the motor case drain to that hose.
Are you going to get another control valve to control the motors or are you planning on using the cylinder control valve?
connect the pressure supply of the hydraulic valve to this valve in front of the motor: https://www.kramp.com/shop-gb/en/411076/510732/224... (i think this is one of the components you meant?), connect it to the 2 motors (parallel or in series?) and connect it to the return line of the valve.
I plan on using the cylinder control valve. The motors will be controlled from inside the cabin.
EDIT: just saw your new message, changed some text
It would be advisable to use something smaller as a load sense relief valve.
The load sense relief valve would be connected in the same way, but would be used to limit the pump displacement and so could be smaller and cheaper.
What you are trying to do makes sense and it’s not like you are trying to reinvent the wheel.
Which motors are you looking to use? Displacement wise I mean...
I appreciate your help a lot, I'm learning a lot
The load sense relief valve is just a relief valve. It limits the pressure in the load sense line and so limits the max pressure of the pump.
The load sense line runs from the control valve to the pump. The load sense relief valve sits in this line and limits the pressure in the load sense line and therefore limits the pressure that pump will generate.
Motor torque will be 120 Newton metres at 100 Bar. Less a little for efficiency.
How much in not much motor load?
Ted
If your motors will run in one direction only, then you can add a free wheel check valve to allow the motors to run on when the valve is moved to neutral.
What is the middle ground you mentioned? In the middle ground, what is the cylinder doing?
Some motors have inbuilt freewheel check valves.
The main cylinder at the back of the tractor was the one i was thinking about first. Here the height can be controlled quite precisely, because this gets measured and the tractor knows how much more oil is needed to go to the position you gave it.
The connections we want to use for the motor uses a valve like you mentioned. It has 3 main slots where the lever can be placed. One is up, one neutral and one is down. If you place the lever between one of these positions the cylinder moves slower/faster, but the lever wont stick to this position. You have to hold it.
The tractor has position feedback for the rear cylinder from the sounds of it.
The force on the lever is the flow forces acting on the spool.
As discussed, that valve will need to allow the motors to turn when the valve is in neutral.
