force time dependent components
Hello colleagues
I need to model in Abaqus a force which changes its x y and z components over time. I have a tabular data showing me in which time what x y and z corresponds. How can i do that ?
thanx in advance !
thanx in advance !
RE: force time dependent components
I made some but cant match time increments and steps, so cannot calculate the results.
in the same step if i use the same force but without amplitude, then it solves, which makes me thing the rest is OK...
The incrementation is not controlled by the amplitude, so the user has to use the step settings to influence the incrementation.
I would recommend to learn the Abaqus basics first. The Getting Started in the Abaqus documentation is a good start.
