Linking P/N to note
Linking P/N to note
RE: Linking P/N to note
My drawings are linked to the part number of the part\assembly that is placed onto the drawing Sheet. I link it using this $PRPSHEET:"SW-File Name(File Name)"
RMB the note and select "edit text in window".
Scott Baugh, CSWP pc2
CAD Systems Manager
Evapar
www.evapar.com
Quote:
"If it's not broke, Don't fix it!"
Note:
See Model File $PRPSHEET:"PartNumber"_$PRPSHEET:"Revision".sldprt
For $PRPSHEET:"Description" Geometry Definition
Make sure you have the appropriate custom properties set up in the sldprt or sldasm files.
Anna Wood
SW2015 SP5, Windows 7 x64
