How to check solid visibility in VB ?
In the below code, I didn't succeed to test the solid visibility. Something is wrong in the syntax NXOpen.SmartObject.VisibilityOption.Visible....
Thanks in advance to help me
For Each body In bodies
If body.name = solide1 Then
objects1(0) = body
If NXOpen.SmartObject.VisibilityOption.Visible(solide1) Then
s.DisplayManager.BlankObjects(objects1)
Else
s.DisplayManager.ShowObjects(objects1, DisplayManager.LayerSetting.ChangeLayerToSelectable)
End If
End If
Next body
Didier Psaltopoulos
http://www.psi-cad.fr
RE: How to check solid visibility in VB ?
The visibility option as shown in your code above only applies to smart objects, not all graphical objects in the display. There are a number of factors that affect object visibility within a part, the 2 main ones are the hidden status (.IsBlanked) and the object's layer visibility. The .AskVisibleObjects method is also useful; it is made for drafting views, but also gives some information on modeling views.
www.nxjournaling.com
Hi Cowski,
I found the solution with the following code
objects1(0) = body
Dim disProps As UFObj.DispProps
ufs.Obj.AskDisplayProperties(objects1(0).Tag, disProps)
If disProps.blank_status = UFConstants.UF_OBJ_BLANKED Then
' la ligne ci-dessous sert à afficher
Else
' la ligne ci-dessous sert à cacher
End If
End If
Next body
Didier Psaltopoulos
