RISAConnection going to offer HSS members in Moment Connections?
Andrew and/or Josh,
Is RISA intending to incorporate HSS columns into the moment connection designs within RISAConnection? I am doing more of these type of connections (WF Beam-HSS Column) and it would be helpful instead of designing by hand.
RE: RISAConnection going to offer HSS members in Moment Connections?
It used to be that my goal for each release was the following:
a) The main new feature for that release (whatever it was).
b) Add at least one significant advancement for HSS connections.
c) Convert one group of connections from AISC to CSA (Canadian code).
My belief is that's still the goal. I believe they've added HSS column options to a number of the connections for recent releases. I think they have HSS to HSS moment connections now. It's HSS to WF moment connections that it's currently lacking. If I remember correctly, next up will be HSS columns cap plated with a WF running over the top. Then (perhaps at the same time), a continuous WF column with an HSS end plate bolted to it. Essentially the same connection, but from different perspectives.
The challenging thing for RISA is that two of the three most experienced connection designers (Matt and myself) have left in the last 6 months or so. Leaving Caitlin a little overloaded. Therefore, I would not be surprised if development slowed down a bit. Sometimes the developers themselves can take lead on a particular feature. They're certainly smart enough. But, that tends to lead to QA/QC issues because you don't get enough sets of eyes looking at the feature from the point of view of a practicing engineer.
