brake fluid reservoir - material
Hello colleagues,
I'm new on this forum and just need some help. I'm working for 3d printer producer and I have the case study to do:
I have to print brake fluid reservoir that is normally used in cars...
Do you have any idea what is the original material that such reservoires are made of? I do not know if every kind of filament will handle the chemical requirements that such reservoires have to pass. Maybe the brake fluid has some special chemical prosperities?
I'll be very glad for your help.
PS. If I added this topic to the wrong section of forum please forgive me.
RE: brake fluid reservoir - material
Andrew H.
www.mototribology.com
Dan - Owner
http://www.Hi-TecDesigns.com
Cheers
Greg Locock
We do not have HDPE in use so, do you think the PETG (Polyethylene Terepthalate Glycol) is correct for such thing?
According to http://kmac-plastics.net/data/chemical/petg-chemic... it hasn't been tested by them.
There is this: https://discuss.toms3d.org/filaments-f10/filament-...
So now just hope the printer manage to print two exact the same samples...
Keith Cress
I'll let you know when the examine is done.
Dan - Owner
